A factorization method for elliptic BVP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The technique of space invariant embedding, applied to a second order boundary value problem de ned in a cylindrical domain, gives rise to a system of uncoupled rst order initial value problems that includes a non-linear Riccati equation on a unbounded functional operator. We present a method to justify this equation that uses a parabolic regularization of the original problem.
proceedings-murcia-semtemplate.pdf (309.55 Ko) Télécharger le fichier
hal-00869508 , version 1 (14-10-2013)
  • HAL Id : hal-00869508 , version 1
Jacques Henry, Bento Louro, Maria Do Céu Soares. A factorization method for elliptic BVP. 12th International Conference on Computational and Mathematical Methods in Science and Engineering, CMMSE 2012, 2012, Murcia, Spain. ⟨hal-00869508⟩
233 Consultations
208 Téléchargements
