The geometry of some parameterizations and encodings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Mathematics of Communications Année : 2014
We report on current work on parameterization of low genera algebraic curves. For example, we prove that for $q$ a prime power that is large enough and prime to 6, a fixed positive proportion of all genus two curves over the field with $q$ elements can be parameterized by 3-radicals. This results in the existence of a deterministic encoding into these curves when $q$ is congruent to 2 modulo 3. Abstract of a talk given at GEOCRYPT 2013, Papeete.
g2.pdf (344.52 Ko) Télécharger le fichier
hal-00870112 , version 1 (16-02-2021)
Jean-Marc Couveignes, Reynald Lercier. The geometry of some parameterizations and encodings. Advances in Mathematics of Communications, 2014, 8 (4), pp.22. ⟨10.3934/amc.2014.8.437⟩. ⟨hal-00870112⟩
414 Consultations
50 Téléchargements
