Computing Period and Shape of Oscillations in Piecewise Linear Lur'e Systems: a Complementarity Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autonomous piecewise linear systems in the Lur'e form may exhibit periodic steady-state oscillations. For many practical systems belonging to this class the period and the shape of the oscillation is difficult to be predicted a priori. In this paper the complementarity approach is used to tackle the issue. The complementarity formalism is used to represent the closed-loop system and a phase condition acting as an anchor equation for the periodic solution. By discretizing the dynamics a mixed complementarity problem is formulated. The corresponding solution provides an accurate prediction of the steady-state oscillation and its period. Numerical results show the effectiveness of the proposed technique for the computation of stable and sliding periodic solutions. The analysis of the steady-state solution of a Colpitts oscillator is considered as an illustration.
Sessa.ea_CDC13_0491_FI.pdf (221.6 Ko) Télécharger le fichier
hal-00870282 , version 1 (06-10-2013)
Valentina Sessa, Luigi Iannelli, Vincent Acary, Bernard Brogliato, Francesco Vasca. Computing Period and Shape of Oscillations in Piecewise Linear Lur'e Systems: a Complementarity Approach. CDC 2013 - 52nd IEEE Conference on Decision and Control, Dec 2013, Firenze, Italy. pp.4680-4685, ⟨10.1109/CDC.2013.6760622⟩. ⟨hal-00870282⟩
297 Consultations
392 Téléchargements
