Robust optimization in multi-operators microwave backhaul networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we consider the problem of sharing the infrastructure of a backhaul network, called fixed broadband wireless network using microwave links, for routing. We investigate in particular on the revenue maximization problem for the physical network operator (PNO) when subject to stochastic traffic requirements of multiple virtual network operators (VNO) and prescribed service level agreements (SLA). We use robust optimization to study the tradeoff between revenue maximization and the allowed level of uncertainty in the traffic demands. We propose a mathematical programming formulation of our robust optimization problem using mixed integer linear programming. This model takes into account end-to-end traffic delays as example of quality-of-service requirement in a SLA. To show the effectiveness of our model, we present a study on the price of robustness, i.e. the additional price to pay in order to obtain a feasible solution for the robust scheme, on realistic scenarios.
CCK13--GISS13.pdf (1 Mo) Télécharger le fichier
hal-00870931 , version 1 (08-10-2013)
  • HAL Id : hal-00870931 , version 1
Christelle Caillouet, David Coudert, Alvinice Kodjo. Robust optimization in multi-operators microwave backhaul networks. 4th Global Information Infrastructure and Networking Symposium, Oct 2013, Trento, Italy. pp.1-6. ⟨hal-00870931⟩
222 Consultations
314 Téléchargements
