A Conjugate Gradient Algorithm for Blind Sensor Calibration in Sparse Recovery - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This work studies the problem of blind sensor calibration (BSC) in linear inverse problems, such as compressive sens- ing. It aims to estimate the unknown complex gains at each sensor, given a set of measurements of some unknown train- ing signals. We assume that the unknown training signals are all sparse. Instead of solving the problem by using con- vex optimization, we propose a cost function on a suitable manifold, namely, the set of complex diagonal matrices with determinant one. Such a construction can enhance numerical stabilities of the proposed algorithm. By exploring a global parameterization of the manifold, we tackle the BSC prob- lem with a conjugate gradient method. Several numerical experiments are provided to oppose our approach to the so- lutions given by convex optimization and to demonstrate its performance.
mlsp13.pdf (224.45 Ko) Télécharger le fichier
hal-00871323 , version 1 (09-10-2013)
  • HAL Id : hal-00871323 , version 1
Hao Shen, Martin Kleinsteuber, Cagdas Bilen, Rémi Gribonval. A Conjugate Gradient Algorithm for Blind Sensor Calibration in Sparse Recovery. IEEE International Workshop on Machine Learning for Signal Processing - 2013, Sep 2013, Southampton, United Kingdom. ⟨hal-00871323⟩
261 Consultations
211 Téléchargements
