A parallel hybrid evolutionary algorithm for the optimization of broker virtual machines subletting in cloud systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article presents a new parallel hybrid evolutionary algorithm to solve the problem of virtual machines subletting in cloud systems. The problem deals with the efficient allocation of a set of virtual machine requests from customers into available pre-booked resources from a cloud broker, in order to maximize the broker profit. The proposed parallel algorithm uses a distributed subpopulations model, and a Simulated Annealing operator. The experimental evaluation analyzes the profit and make span results of the proposed methods over a set of problem instances that account for realistic workloads and scenarios using real data from cloud providers. A comparison with greedy heuristics indicates that the proposed method is able to compute solutions with up to 133.8% improvement in the profit values, while accounting for accurate make span results.
hal-00872986 , version 1 (14-10-2013)
Santiago Iturriaga, Sergio Nesmachnow, Bernabé Dorronsoro, El-Ghazali Talbi, Pascal Bouvry. A parallel hybrid evolutionary algorithm for the optimization of broker virtual machines subletting in cloud systems. SCCG 2013 - 2nd International Workshop on Soft Computing Techniques in Cluster and Grid Computing Systems, Oct 2013, Compiegne, France. pp.594-599, ⟨10.1109/3PGCIC.2013.103⟩. ⟨hal-00872986⟩
71 Consultations
0 Téléchargements
