Concurrency Control and Awareness Support for Multi-synchronous Collaborative Editing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Collaborative editing tools have become increasingly popular in the last decade, with some systems being used by massive numbers of users. While traditionally collaborative editing systems would either target synchronous or asynchronous collaboration settings, some recent systems support both types of collaboration, even supporting disconnected work. In this paper we analyze the limitations of existing systems and propose a data management solution that overcomes such limitations. The proposed concurrency control algorithm, based on conflict-free data types, builds on the ideas previously developed for synchronous collaboration, extending them to support asynchronous collaboration. Our solution also includes the necessary information for providing comprehensive awareness information to users. The evaluation of our algorithm shows that comparing our solution with traditional solutions in collaborative editing, the conflict resolution strategy proposed in this paper leads to results closer to the ones expected by users.
138101036819436.pdf (1.46 Mo) Télécharger le fichier
hal-00873496 , version 1 (15-10-2013)
  • HAL Id : hal-00873496 , version 1
Mehdi Ahmed-Nacer, Pascal Urso, Balegas Valter, Nuno Preguiça. Concurrency Control and Awareness Support for Multi-synchronous Collaborative Editing. COLLABORATECOM 2013 - 9th IEEE International. Conference on Collaborative Computing: Networking, Applications and Worksharing, Oct 2013, Austin, Texas, United States. ⟨hal-00873496⟩
459 Consultations
664 Téléchargements
