Modeling the grand piano - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A global model of a piano is presented. Its aim is to reproduce the main vibratory and acoustic phenomena involved in the generation of a piano sound from the initial blow of the hammer against the strings to the radiation from soundboard to the air. One first originality of the work is due to the string model which takes both geometrical nonlinear effects and stiffness into account. Other significant improvements are due to the combined modeling of the three main couplings between the constitutive parts of the instrument: hammer-string, string-soundboard and soundboard-air coupling.
Mots clés
waves2013_submission_154.pdf (47.07 Ko) Télécharger le fichier
hal-00873616 , version 1 (16-10-2013)
  • HAL Id : hal-00873616 , version 1
Antoine Chaigne, Juliette Chabassier, Patrick Joly. Modeling the grand piano. WAVES 13 : 11th International Conference on Mathematical and Numerical Aspects of Waves, Jun 2013, Tunis, Tunisia. ⟨hal-00873616⟩
277 Consultations
157 Téléchargements
