Sensitivity of rough differential equations: an approach through the Omega lemma - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Differential Equations Année : 2018
The Itô map assigns the solution of a Rough Differential Equation, a generalization of an Ordinary Differential Equation driven by an irregular path, when existence and uniqueness hold. By studying how a path is transformed through the vector field which is integrated, we prove that the Itô map is Hölder or Lipschitz continuous with respect to all its parameters. This result unifies and weakens the hypotheses of the regularity results already established in the literature.
sensitivity-RDE_R2.pdf (313.31 Ko) Télécharger le fichier
hal-00875670 , version 1 (22-10-2013)
hal-00875670 , version 2 (06-03-2015)
hal-00875670 , version 3 (25-05-2016)
hal-00875670 , version 4 (14-10-2016)
hal-00875670 , version 5 (31-10-2017)
hal-00875670 , version 6 (12-12-2017)
Copyright (Tous droits réservés)
Laure Coutin, Antoine Lejay. Sensitivity of rough differential equations: an approach through the Omega lemma. Journal of Differential Equations, 2018, 264 (6), pp.3899-3917. ⟨10.1016/j.jde.2017.11.031⟩. ⟨hal-00875670v6⟩
800 Consultations
718 Téléchargements
