Error estimates for 1D asymptotic models in coaxial cables with non-homogeneous cross-section - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Applied Mechanics Année : 2012
This paper is the first contribution towards the rigorous justification of asymptotic 1D models for the time-domain simulation of the propagation of electromagnetic waves in coaxial cables. Our general objective is to derive error estimates between the "exact" solution of the full 3D model and the "approximate" solution of the 1D model known as the Telegraphist's equation.
coaxial_cables_analysis.pdf (931.35 Ko) Télécharger le fichier
hal-00875808 , version 1 (22-10-2013)
hal-00875808 , version 2 (21-11-2018)
Sébastien Imperiale, Patrick Joly. Error estimates for 1D asymptotic models in coaxial cables with non-homogeneous cross-section. Advances in Applied Mechanics, 2012, xx, ⟨10.4208/aamm.12-12S06⟩. ⟨hal-00875808v2⟩
432 Consultations
294 Téléchargements
