Hierarchical super-resolution-based inpainting - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Image Processing Année : 2013
This paper introduces a novel framework for examplar-based inpainting. It consists in performing first the inpainting on a coarse version of the input image. A hierarchical super-resolution algorithm is then used to recover details on the missing areas. The advantage of this approach is that it is easier to inpaint low-resolution pictures than high resolution ones. The gain is both in terms of computational complexity and visual quality. However, to be less sensitive to the parameter setting of the inpainting method, the low-resolution input picture is inpainted several times with different configurations. Results are efficiently combined with a loopy belief propagation and details are recovered by a single-image super-resolution algorithm. Experimental results in a context of image editing and texture synthesis demonstrate the effectiveness of the proposed method. Results are compared to five state-of-the-art inpainting methods.
LeMeur_Inpainting_V3.0_doubleColumn.pdf (25.73 Mo) Télécharger le fichier
Format : Figure, Image
hal-00876168 , version 1 (21-11-2014)
Olivier Le Meur, Mounira Ebdelli, Christine Guillemot. Hierarchical super-resolution-based inpainting. IEEE Transactions on Image Processing, 2013, 22 (10), pp.3779-3790. ⟨10.1109/TIP.2013.2261308⟩. ⟨hal-00876168⟩
315 Consultations
840 Téléchargements
