Efficient saliency detection using regional color and spatial information - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose an efficient saliency model using regional color and spatial information. The original image is first segmented into a set of regions using a superpixel segmentation algorithm. For each region, its color saliency is evaluated based on the color similarity measures with other regions, and its spatial saliency is evaluated based on its color distribution and spatial position. The final saliency map is generated by combining color saliency measures and spatial saliency measures of regions. Experimental results on a public dataset containing 1000 images demonstrate that our computationally efficient saliency model outperforms the other six state-of-the-art models on saliency detection performance.
Luo_EUVIP2013.pdf (1011.42 Ko) Télécharger le fichier
poster_EUVIP_new.pdf (1.95 Mo) Télécharger le fichier
Format : Autre
hal-00876192 , version 1 (24-10-2013)
  • HAL Id : hal-00876192 , version 1
Shuhua Luo, Zhi Liu, Li Lina, Xuemei Zou, Olivier Le Meur. Efficient saliency detection using regional color and spatial information. EUVIP, Jun 2013, Paris, France. ⟨hal-00876192⟩
246 Consultations
247 Téléchargements
