A fictitious domain method with mixed finite elements for elastodynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Scientific Computing Année : 2007
We consider in this paper the wave scattering problem by an object with Neumann boundary conditions in an anisotropic elastic body. To obtain an efficient numerical method (permitting the use of regular grids) we follow a fictitious domain approach coupled with a first order velocity stress formulation for elastodynamics. We first observe that the method does not always converge when the Qdiv1 - Q0 finite element is used. In particular, the method converges for some scattering object geometries but not for others. Note that the convergence of the Qdiv1 - Q0 finite element method was shown in [E. Bécache, P. Joly, and C. Tsogka, SIAM J. Numer. Anal., 39 (2002), pp. 2109-2132] for the elastodynamic problem in the absence of a scattering object (i.e., without the coupling of the mixed finite elements with the fictitious domain method). Therefore we propose here a modification of the Q div1 - Q0 element following the approach in [E. Bécache, J. Rodríguez, and C. Tsogka, On the convergence of the fictitious domain method for wave equation problems, Technical report 5802, INRIA, 2006], where the simpler acoustic case was considered. To study the numerical properties of the new element we carry out a dispersion analysis. Several numerical simulations as well as a numerical convergence analysis show that the proposed method provides a good approximate solution. © 2007 Society for Industrial and Applied Mathematics.
hal-00876222 , version 1 (24-10-2013)
Eliane Bécache, Jerónimo Rodríguez, Chrysoula Tsogka. A fictitious domain method with mixed finite elements for elastodynamics. SIAM Journal on Scientific Computing, 2007, 29 (3), pp.1244-1267. ⟨10.1137/060655821⟩. ⟨hal-00876222⟩
123 Consultations
0 Téléchargements
