Locating an obstacle in a 3D finite depth ocean using the convex scattering support - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2007
We consider an inverse scattering problem in a 3D homogeneous shallow ocean. Specifically, we describe a simple and efficient inverse method which can compute an approximation of the vertical projection of an immersed obstacle. This reconstruction is obtained from the far-field patterns generated by illuminating the obstacle with a single incident wave at a given fixed frequency. The technique is based on an implementation of the theory of the convex scattering support [S. Kusiak, J. Sylvester, The scattering support, Commun. Pure Appl. Math. (2003) 1525-1548]. A few examples are presented to show the feasibility of the method. © 2006 Elsevier B.V. All rights reserved.
hal-00876231 , version 1 (25-10-2013)
Laurent Bourgeois, Colin Chambeyron, Steven Kusiak. Locating an obstacle in a 3D finite depth ocean using the convex scattering support. Journal of Computational and Applied Mathematics, 2007, 204 (2 SPEC. ISS.), pp.387-399. ⟨10.1016/j.cam.2006.01.045⟩. ⟨hal-00876231⟩
125 Consultations
0 Téléchargements
