Time-harmonic acoustic propagation in the presence of a shear flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2007
This work deals with the numerical simulation, by means of a finite element method, of the time-harmonic propagation of acoustic waves in a moving fluid, using the Galbrun equation instead of the classical linearized Euler equations. This work extends a previous study in the case of a uniform flow to the case of a shear flow. The additional difficulty comes from the interaction between the propagation of acoustic waves and the convection of vortices by the fluid. We have developed a numerical method based on the regularization of the equation which takes these two phenomena into account. Since it leads to a partially full matrix, we use an iterative algorithm to solve the linear system. © 2006 Elsevier B.V. All rights reserved.
hal-00876232 , version 1 (25-10-2013)
Anne-Sophie Bonnet-Ben Dhia, Ève-Marie Duclairoir, Guillaume Legendre, Jean-François Mercier. Time-harmonic acoustic propagation in the presence of a shear flow. Journal of Computational and Applied Mathematics, 2007, 204 (2 SPEC. ISS.), pp.428-439. ⟨10.1016/j.cam.2006.02.048⟩. ⟨hal-00876232⟩
136 Consultations
0 Téléchargements
