Integration of fuzzy spatial relations in deformable models - application to brain MRI segmentation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pattern Recognition Année : 2006
This paper presents a general framework to integrate a new type of constraints, based on spatial relations, in deformable models. In the proposed approach, spatial relations are represented as fuzzy subsets of the image space and incorporated in the deformable model as a new external force. Three methods to construct an external force from a fuzzy set representing a spatial relation are introduced and discussed. This framework is then used to segment brain subcortical structures in Magnetic Resonance Images (MRI). A training step is proposed to estimate the main parameters defining the relations. The results demonstrate that the introduction of spatial relations in a deformable model can substantially improve the segmentation of structures with low contrast and ill-defined boundaries.
pr2006-Final-Single.pdf (1.29 Mo) Télécharger le fichier
hal-00878443 , version 1 (30-10-2013)
Olivier Colliot, Oscar Camara, Isabelle Bloch. Integration of fuzzy spatial relations in deformable models - application to brain MRI segmentation. Pattern Recognition, 2006, 39 (8), pp.1401-1414. ⟨10.1016/j.patcog.2006.02.022⟩. ⟨hal-00878443⟩
179 Consultations
620 Téléchargements
