Symbolically Bounding the Drift in Time-Constrained MSC-Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Verifying systems involving both time and concurrency rapidly leads to undecidability, and requires restrictions to become eff ective. This paper addresses the emptiness problem for time-constrained MSC-Graphs (TC-MSC graphs for short), that is, checking whether there is a timed execution compatible with a TC-MSC graph speci cation. This problem is known to be undecidable in general [11], and decidable for some regular speci cations [11]. We establish decidability of the emptiness problem under the condition that, for a given K, no path of the TC-MSC graph forces any node to take more than K time units to complete. We prove that this condition can be e ffectively checked. The proofs use a novel symbolic representation for runs, where time constraints are encoded as a system of inequalities. This allows us to handle non-regular speci cations and improve effi ciency w.r.t. using interleaved representations.
AGHY12full.pdf (387.56 Ko) Télécharger le fichier
hal-00879831 , version 1 (05-11-2013)
  • HAL Id : hal-00879831 , version 1
Sundararaman Akshay, Blaise Genest, Loic Helouet, Shaofa Yang. Symbolically Bounding the Drift in Time-Constrained MSC-Graphs. International Colloquium on Theoretical Aspects of Computing, IIT Bangalore, Sep 2012, Bangalore, India. pp.1-15. ⟨hal-00879831⟩
497 Consultations
70 Téléchargements
