Backward under-approximations in numeric abstract domains to automatically infer sufficient program conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science of Computer Programming Année : 2013
In this article, we discuss the automatic inference of sufficient preconditions by abstract interpretation and sketch the construction of an under-approximating backward analysis. We focus on numeric properties of variables and revisit three classic numeric abstract domains: intervals, octagons, and polyhedra, with new under-approximating backward transfer functions, including the support for non-deterministic expressions, as well as lower widenings to handle loops. We show that effective under-approximation is possible natively in these domains without necessarily resorting to disjunctive completion nor domain complementation. Applications include the derivation of sufficient conditions for a program to never step outside an envelope of safe states, or dually to force it to eventually fail. We built a proof-of-concept prototype implementation and tried it on simple examples. Our construction and our implementation are very preliminary and mostly untried; our hope is to convince the reader that this constitutes a worthy avenue of research.
journal_SCP_ok.pdf (396 Ko) Télécharger le fichier
hal-00903628 , version 1 (12-11-2013)
Antoine Miné. Backward under-approximations in numeric abstract domains to automatically infer sufficient program conditions. Science of Computer Programming, 2013, ⟨10.1016/j.scico.2013.09.014⟩. ⟨hal-00903628⟩
233 Consultations
522 Téléchargements
