Hyperparameter estimation for uncertainty quantification in mesoscale carbon dioxide inversions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Tellus B - Chemical and Physical Meteorology Année : 2013
Uncertainty quantification is critical in the inversion of CO2 surface fluxes from atmospheric concentration measurements. Here, we estimate the main hyperparameters of the error covariance matrices for a priori fluxes and CO2 concentrations, that is, the variances and the correlation lengths, using real, continuous hourly CO2 concentration data in the context of the Ring 2 experiment of the North American Carbon Program Mid Continent Intensive. Several criteria, namely maximum likelihood (ML), general cross-validation (GCV) and x2 test are compared for the first time under a realistic setting in a mesoscale CO2 inversion. It is shown that the optimal hyperparameters under the ML criterion assure perfect x2 consistency of the inverted fluxes. Inversions using the ML error variances estimates rather than the prescribed default values are less weighted by the observations, because the default values underestimate the model-data mismatch error, which is assumed to be dominated by the atmospheric transport error. As for the spatial correlation length in prior flux errors, the Ring 2 network is sparse for GCV, and this method fails to reach an optimum. In contrast, the ML estimate (e.g. an optimum of 20 km for the first week of June 2007) does not support long spatial correlations that are usually assumed in the default values.
20894-107222-1-PB.pdf (738.75 Ko) Télécharger le fichier
hal-00904142 , version 1 (13-11-2013)
Lin Wu, Marc Bocquet, Frédéric Chevallier, Thomas Lauvaux, Kenneth Davis. Hyperparameter estimation for uncertainty quantification in mesoscale carbon dioxide inversions. Tellus B - Chemical and Physical Meteorology, 2013, 65, ⟨10.3402/tellusb.v65i0.20894⟩. ⟨hal-00904142⟩
291 Consultations
287 Téléchargements
