A Recursive Approach For Multiclass Support Vector Machine: Application to Automatic Classification of Endomicroscopic Videos - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Alexis Zubiolo
  • Fonction : Auteur
  • PersonId : 948502
Barbara André
  • Fonction : Auteur
  • PersonId : 902248
Eric Debreuve
Grégoire Malandain
The two classical steps of image or video classification are: image signature extraction and assignment of a class based on this image signature. The class assignment rule can be learned from a training set composed of sample images manually classified by experts. This is known as supervised statistical learning. The well-known Support Vector Machine (SVM) learning method was designed for two classes. Among the proposed extensions to multiclass (three classes or more), the one-versus-one and one-versus-all approaches are the most popular ones. This work presents an alternative approach to extending the original SVM method to multiclass. A tree of SVMs is built using a recursive learning strategy, achieving a linear worst-case complexity in terms of number of classes for classification. During learning, at each node of the tree, a bi-partition of the current set of classes is determined to optimally separate the current classification problem into two sub-problems. Rather than relying on an exhaustive search among all possible subsets of classes, the partition is obtained by building a graph representing the current problem and looking for a minimum cut of it. The proposed method is applied to classification of endomicroscopic videos and compared to classical multiclass approaches.
Example.pdf (584.77 Ko) Télécharger le fichier
hal-00905382 , version 1 (18-11-2013)
  • HAL Id : hal-00905382 , version 1
Alexis Zubiolo, Barbara André, Eric Debreuve, Grégoire Malandain. A Recursive Approach For Multiclass Support Vector Machine: Application to Automatic Classification of Endomicroscopic Videos. VISAPP - International Conference on Computer Vision Theory and Applications, Jan 2014, Lisbon, Portugal. ⟨hal-00905382⟩
399 Consultations
278 Téléchargements
