Weak backward error analysis for overdamped Langevin processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2015
We consider numerical approximations of overdamped Langevin stochastic differential equations by implicit methods. We show a weak backward error analysis result in the sense that the generator associated with the numerical solution coincides with the solution of a modified Kolmogorov equation up to high order terms with respect to the stepsize. This implies that every measure of the numerical scheme is close to a modified invariant measure obtained by asymptotic expansion. Moreover, we prove that, up to negligible terms, the dynamic associated with the implicit scheme considered is exponentially mixing.
hal-00905684 , version 1 (18-11-2013)
Marie Kopec. Weak backward error analysis for overdamped Langevin processes. IMA Journal of Numerical Analysis, 2015, 35 (2), pp.583-614. ⟨10.1093/imanum/dru016⟩. ⟨hal-00905684⟩
162 Consultations
0 Téléchargements
