Probabilistic Integration of Intensity and Depth Information for Part-Based Vehicle Detection - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Intelligent Transportation Systems Année : 2013
In this paper, an object class recognition method is presented. The method uses local image features and follows the part-based detection approach. It fuses intensity and depth information in a probabilistic framework. The depth of each local feature is used to weigh the probability of finding the object at a given distance. To train the system for an object class, only a database of images annotated with bounding boxes is required, thus automatizing the extension of the system to different object classes. We apply our method to the problem of detecting vehicles from a moving platform. The experiments with a data set of stereo images in an urban environment show a significant improvement in performance when using both information modalities.
06575156.pdf (1.07 Mo) Télécharger le fichier
hal-00905703 , version 1 (08-01-2014)
Alexandros Makris, Mathias Perrollaz, Christian Laugier. Probabilistic Integration of Intensity and Depth Information for Part-Based Vehicle Detection. IEEE Transactions on Intelligent Transportation Systems, 2013, 14 (4), pp.1896-1906. ⟨10.1109/TITS.2013.2271113⟩. ⟨hal-00905703⟩
240 Consultations
393 Téléchargements
