On the Grundy and b-chromatic numbers of a graph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithmica Année : 2013
The Grundy number of a graph G, denoted by Γ(G), is the largest k such that G has a greedy k-colouring, that is a colouring with k colours obtained by applying the greedy algorithm according to some ordering of the vertices of G. Trivially Γ (G) ≤ ∆(G) + 1. In this paper, we show that deciding if Γ (G) ≤ ∆(G) is NP-complete. We then show that deciding if Γ (G) ≥ |V (G)| − k is fixed parameter tractable with respect to the parameter k.
FPT-dual-greedy.pdf (176.77 Ko) Télécharger le fichier
hal-00905927 , version 1 (23-10-2016)
  • HAL Id : hal-00905927 , version 1
Frédéric Havet, Leonardo Sampaio. On the Grundy and b-chromatic numbers of a graph. Algorithmica, 2013, 65 (4), pp.885-899. ⟨hal-00905927⟩
330 Consultations
159 Téléchargements
