Syntactic Computation of Hybrid Possibilistic Conditioning under Uncertain Inputs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We extend hybrid possibilistic conditioning to deal with inputs consisting of a set of triplets composed of propositional formulas, the level at which the formulas should be accepted, and the way in which their models should be revised. We characterize such conditioning using elementary operations on possibility distributions. We then solve a difficult issue that concerns the syntactic computation of the revision of possibilistic knowledge bases, made of weighted formulas, using hybrid conditioning. An important result is that there is no extra computational cost in using hybrid possibilistic conditioning and in particular the size of the revised possibilistic base is polynomial with respect to the size of the initial base and the input.
ijcai2013.pdf (137.21 Ko) Télécharger le fichier
hal-00905935 , version 1 (19-11-2013)
  • HAL Id : hal-00905935 , version 1
Salem Benferhat, Célia da Costa Pereira, Andrea G. B. Tettamanzi. Syntactic Computation of Hybrid Possibilistic Conditioning under Uncertain Inputs. IJCAI, Aug 2013, Beijing, China. pp.6822. ⟨hal-00905935⟩
283 Consultations
436 Téléchargements
