Linear Dependent Types and Relative Completeness - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Logical Methods in Computer Science Année : 2012
A system of linear dependent types for the lambda calculus with full higher-order recursion, called dℓPCF, is introduced and proved sound and relatively complete. Completeness holds in a strong sense: dℓPCF is not only able to precisely capture the functional behaviour of PCF programs (i.e. how the output relates to the input) but also some of their intensional properties, namely the complexity of evaluating them with Krivine's Machine. dℓPCF is designed around dependent types and linear logic and is parametrized on the underlying language of index terms, which can be tuned so as to sacrifice completeness for tractability.
Informatique
1104.0193.pdf (436.23 Ko) Télécharger le fichier
hal-00906347 , version 1 (19-11-2013)
  • HAL Id : hal-00906347 , version 1
Ugo Dal Lago, Marco Gaboardi. Linear Dependent Types and Relative Completeness. Logical Methods in Computer Science, 2012, 8 (4). ⟨hal-00906347⟩
Collections
INRIA INRIA2
205 Consultations
189 Téléchargements
