Self Calibration of Gough Platform using leg mobility constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1999
David Daney
A new algorithm for the calibration of a gough platform is presented. It enables auto-calibration as it only uses internal measurements : the leg lengths In order to obtain the necessary information to do so, without adding additional sensors. we introduce some constraints on two legs of the robot. First, the method is described. Second, it is validated by simulation.
iftomm.pdf (202.05 Ko) Télécharger le fichier
hal-00906476 , version 1 (19-11-2013)
  • HAL Id : hal-00906476 , version 1
David Daney. Self Calibration of Gough Platform using leg mobility constraints. 10th world congress of International Federation for the Theory of Machines and Mechanisms (IFToMM), Jun 1999, Oulu, Finland. pp.104-109. ⟨hal-00906476⟩
481 Consultations
66 Téléchargements
