A Study on the Correspondence between FCA and ELI Ontologies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Amedeo Napoli
The description logic EL has been used to support ontology design in various domains, and especially in biology and medicine. EL is known for its efficient reasoning and query answering capabilities. By contrast, ontology design and query answering can be supported and guided within an FCA framework. Accordingly, in this paper, we propose a formal transformation of ELI (an extension of EL with inverse roles) ontologies into an FCA framework, i.e. KELI, and we provide a formal characterization of this transformation. Then we show that SPARQL query answering over ELI ontologies can be reduced to lattice query answering over KELI concept lattices. This simplifies the query answering task and shows that some basic semantic web tasks can be improved when considered from an FCA perspective.
iswc2013p.pdf (89.24 Ko) Télécharger le fichier
hal-00906736 , version 1 (20-11-2013)
  • HAL Id : hal-00906736 , version 1
Melisachew Wudage Chekol, Amedeo Napoli. A Study on the Correspondence between FCA and ELI Ontologies. ISWC - The 12th International Semantic Web Conference - 2013, Oct 2013, Sydney, Australia. ⟨hal-00906736⟩
129 Consultations
82 Téléchargements
