Construction of Lyapunov functionals for coupled differential and continuous time difference equations. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new stability analysis technique for systems composed of a differential equation coupled with a continuous time difference equation is proposed. It is based on the explicit construction of Lyapunov functionals from the knowledge of Lyapunov functions for subsystems. Robustness results of iISS type are inferred from these functionals.
Constructions de fonctionnelles de Lyapunov pour des systèmes composées d'une équation différentielle et d'une équation aux différences.
Automatique
Fichier non déposé
hal-00906815 , version 1 (20-11-2013)
Frédéric Mazenc, Hiroshi Ito, Pierdomenico Pepe. Construction of Lyapunov functionals for coupled differential and continuous time difference equations.. 52nd IEEE Conference on Decision and Control CDC 2013, Dec 2013, Florence, Italy. pp.2245-2250, ⟨10.1109/CDC.2013.6760215⟩. ⟨hal-00906815⟩
368 Consultations
0 Téléchargements
