Abstraction Pathologies In Markov Decision Processes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Manel Tagorti
  • Fonction : Auteur
  • PersonId : 948730
Bruno Scherrer
Olivier Buffet
Abstraction is a common method to compute lower bounds in classical planning, imposing an equivalence relation on the state space and deriving the lower bound from the quotient system. It is a trivial and well-known fact that refined abstractions can only improve the lower bound. Thus, when we embarked on applying the same technique in the probabilistic setting, our firm belief was to find the same behavior there. We were wrong. Indeed, there are cases where every direct refinement step (splitting one equivalence class into two) yields strictly worse bounds. We give a comprehensive account of the issues involved, for two wide-spread methods to define and use abstract MDPs.
jfpda13-a.pdf (129.57 Ko) Télécharger le fichier
hal-00907295 , version 1 (21-11-2013)
  • HAL Id : hal-00907295 , version 1
Manel Tagorti, Bruno Scherrer, Olivier Buffet, Joerg Hoffmann. Abstraction Pathologies In Markov Decision Processes. 8èmes Journées Francophones sur la Planification, la Décision et l'Apprentissage pour la conduite de systèmes, Jul 2013, Lille, France. ⟨hal-00907295⟩
159 Consultations
110 Téléchargements
