Shader-Based Antialiased Dashed Stroked Polylines - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computer Graphics Techniques Année : 2013
Nicolas P. Rougier
Dashed stroked paths are a widely-used feature found in the vast majority of vector drawing software and libraries. They allow, for example, highlighting a given path such as the cur- rent selection in drawing software or distinguishing curves in the case of a scientific plotting package. This paper introduces a shader-based method for rendering arbitrary dash patterns along any continuous polyline (smooth or broken). The proposed method does not tessellate individual dash patterns and allows for fast and nearly accurate rendering of any user-defined dash pattern and caps. Benchmarks indicates a slowdown ratio between 1.1 and 2.1 with an increased memory consumption between 3 and 6. Furthermore, the method can be used for solid thick polylines with correct caps and joins with only a slowdown of factor 1.1.
paper.pdf (1.71 Mo) Télécharger le fichier
hal-00907326 , version 1 (21-11-2013)
  • HAL Id : hal-00907326 , version 1
Nicolas P. Rougier. Shader-Based Antialiased Dashed Stroked Polylines. Journal of Computer Graphics Techniques, 2013, 2 (2), pp.91-107. ⟨hal-00907326⟩
Collections
CNRS INRIA INRIA2
591 Consultations
9305 Téléchargements
