Linear Convergence of Evolution Strategies with Derandomized Sampling Beyond Quasi-Convex Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study the linear convergence of a simple evolutionary algorithm on non quasi-convex functions on continuous domains. Assumptions include an assumption on the sampling performed by the evolutionary algorithm (supposed to cover efficiently the neighborhood of the current search point), the conditioning of the objective function (so that the probability of improvement is not too low at each time step, given a correct step size), and the unicity of the optimum.
linearConvergence.pdf (520.25 Ko) Télécharger le fichier
hal-00907671 , version 1 (21-11-2013)
  • HAL Id : hal-00907671 , version 1
Jérémie Decock, Olivier Teytaud. Linear Convergence of Evolution Strategies with Derandomized Sampling Beyond Quasi-Convex Functions. EA - 11th Biennal International Conference on Artificial Evolution - 2013, Oct 2013, Bordeaux, France. ⟨hal-00907671⟩
182 Consultations
148 Téléchargements
