Megastereo: Constructing High-Resolution Stereo Panoramas - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a solution for generating high-quality stereo panoramas at megapixel resolutions. While previous approaches introduced the basic principles, we show that those techniques do not generalise well to today's high image resolutions and lead to disturbing visual artefacts. As our first contribution, we describe the necessary correction steps and a compact representation for the input images in order to achieve a highly accurate approximation to the required ray space. Our second contribution is a flow-based upsampling of the available input rays which effectively resolves known aliasing issues like stitching artefacts. The required rays are generated on the fly to perfectly match the desired output resolution, even for small numbers of input images. In addition, the upsampling is real-time and enables direct interactive control over the desired stereoscopic depth effect. In combination, our contributions allow the generation of stereoscopic panoramas at high output resolutions that are virtually free of artefacts such as seams, stereo discontinuities, vertical parallax and other mono-/stereoscopic shape distortions. Our process is robust, and other types of multi-perspective panoramas, such as linear panoramas, can also benefit from our contributions. We show various comparisons and high-resolution results.
Megastereo.pdf (2.25 Mo) Télécharger le fichier
Megastereo-450p.mp4 (29.3 Mo) Télécharger le fichier
Megastereo-poster.pdf (807.86 Ko) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
Format : Autre
hal-00907858 , version 1 (21-11-2013)
Christian Richardt, Yael Pritch, Henning Zimmer, Alexander Sorkine-Hornung. Megastereo: Constructing High-Resolution Stereo Panoramas. CVPR - International Conference on Computer Vision and Pattern Recognition - 2013, Jun 2013, Portland, Oregon, United States. pp.1256-1263, ⟨10.1109/CVPR.2013.166⟩. ⟨hal-00907858⟩
Collections
INRIA INRIA2
202 Consultations
252 Téléchargements
