A Guide to Algorithm Design: Paradigms, Methods, and Complexity Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 2013
Presenting a complementary perspective to standard books on algorithms, A Guide to Algorithm Design: Paradigms, Methods, and Complexity Analysis provides a roadmap for readers to determine the difficulty of an algorithmic problem by finding an optimal solution or proving complexity results. It gives a practical treatment of algorithmic complexity and guides readers in solving algorithmic problems. Divided into three parts, the book offers a comprehensive set of problems with solutions as well as in-depth case studies that demonstrate how to assess the complexity of a new problem. Part I helps readers understand the main design principles and design efficient algorithms. Part II covers polynomial reductions from NP-complete problems and approaches that go beyond NP-completeness. Part III supplies readers with tools and techniques to evaluate problem complexity, including how to determine which instances are polynomial and which are NP-hard. Drawing on the authors' classroom-tested material, this text takes readers step by step through the concepts and methods for analyzing algorithmic complexity. Through many problems and detailed examples, readers can investigate polynomial-time algorithms and NP-completeness and beyond.
TheTableOfContents.pdf (79.31 Ko) Télécharger le fichier
hal-00908448 , version 1 (23-11-2013)
  • HAL Id : hal-00908448 , version 1
Anne Benoit, Yves Robert, Frédéric Vivien. A Guide to Algorithm Design: Paradigms, Methods, and Complexity Analysis. Chapman & Hall/CRC, pp.380, 2013, Applied Algorithms and Data Structures series, 9781439825648. ⟨hal-00908448⟩
1921 Consultations
2942 Téléchargements
