Approximation of the invariant law of SPDEs: error analysis using a Poisson equation for a full-discretization scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IMA Journal of Numerical Analysis Année : 2017
We study the long-time behavior of fully discretized semilinear SPDEs with additive space-time white noise, which admit a unique invariant probability measure $\mu$. We show that the average of regular enough test functions with respect to the (possibly non unique) invariant laws of the approximations are close to the corresponding quantity for $\mu$. More precisely, we analyze the rate of the convergence with respect to the different discretization parameters. Here we focus on the discretization in time thanks to a scheme of Euler type, and on a Finite Element discretization in space. The results rely on the use of a Poisson equation; we obtain that the rates of convergence for the invariant laws are given by the weak order of the discretization on finite time intervals: order $1/2$ with respect to the time-step and order $1$ with respect to the mesh-size.
WevPeFe.pdf (488.16 Ko) Télécharger le fichier
hal-00910323 , version 1 (28-11-2013)
hal-00910323 , version 2 (16-02-2014)
Charles-Edouard Bréhier, Marie Kopec. Approximation of the invariant law of SPDEs: error analysis using a Poisson equation for a full-discretization scheme. IMA Journal of Numerical Analysis, 2017, 37 (3), pp.1. ⟨10.1093/imanum/drw030⟩. ⟨hal-00910323v2⟩
312 Consultations
294 Téléchargements
