Illustrating the Mezzo programming language - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
When programmers want to prove strong program invariants, they are usually faced with a choice between using theorem provers and using traditional programming languages. The former requires them to provide program proofs, which, for many applications, is considered a heavy burden. The latter provides less guarantees and the programmer usually has to write run-time assertions to compensate for the lack of suitable invariants expressible in the type system. We introduce Mezzo, a programming language in the tradition of ML, in which the usual concept of a type is replaced by a more precise notion of a permission. Programs written in Mezzo usually enjoy stronger guarantees than programs written in pure ML. However, because Mezzo is based on a type system, the reasoning requires no user input. In this paper, we illustrate the key concepts of Mezzo, highlighting the static guarantees our language provides.
hal-00910402 , version 1 (28-11-2013)
Jonathan Protzenko. Illustrating the Mezzo programming language. 2013. ⟨hal-00910402⟩
Collections
INRIA INRIA2
66 Consultations
0 Téléchargements
