Assimilation directe de séquences d'images de traceur passif : application aux équations de Saint-Venant - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the last decades satellites datas quantities and qualities have increase. Currently, satellite images sequences, which could provide a lot of information on atmospheric or oceanic system dynamic, are underused in numerical weather forcasting. The aim of this work is to provide new methods to use this information. In this study, we address the topic of monitoring the initial state of a system through the variational assimilation of indirect images sequence. The feasability of the approach is demonstrated on twin experiments realised with a shallow-water model. The influence of the distance definition between two images sequences is studied in presence of data noise.
Gretsi_Full.pdf (215.21 Ko) Télécharger le fichier
hal-00913992 , version 1 (12-12-2013)
  • HAL Id : hal-00913992 , version 1
Vincent Chabot, Maëlle Nodet, Arthur Vidard, Nicolas Papadakis. Assimilation directe de séquences d'images de traceur passif : application aux équations de Saint-Venant. Colloque du Groupe de Recherche et d'Etudes de Traitement du Signal et des Images (GRETSI'13), Sep 2013, Brest, France. pp.1-4. ⟨hal-00913992⟩
484 Consultations
291 Téléchargements
