Video-based methodology for markerless human motion analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This study presents a video-based experiment for the study of markerless human motion. Silhouettes are extracted from a multi-camera video system to reconstruct a 3D mesh for each frame using a reconstruction method based on visual hull. For comparison with traditional motion analysis results, we set up an experiment integrating video recordings from 8 video cameras and a marker-based motion capture system (Vicon™). Our preliminary data provided distances between the 3D trajectories from the Vicon system and the 3D mesh extracted from the video cameras. In the long term, the main ambition of this method is to provide measurement of skeleton motion for human motion analyses while eliminating markers.
ACAPS2013.pdf (108.69 Ko) Télécharger le fichier
Format : Figure, Image
hal-00915093 , version 1 (06-12-2013)
  • HAL Id : hal-00915093 , version 1
Pauline Provini, Julien Pansiot, Lionel Reveret, Olivier A.J. Martin. Video-based methodology for markerless human motion analysis. ACAPS 2013 - 15ème Congrès international de l'Association des Chercheurs en Activités Physiques et Sportives, Oct 2013, Grenoble, France. ⟨hal-00915093⟩
697 Consultations
451 Téléchargements
