Defining Key Semantics for the Semantic Web : a Theoretical View - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2013
Many techniques were recently proposed to automate the linkage of RDF data sources on the Web. Predicate selection is the step of the linkage process that consists in selecting the smallest set of relevant predicates needed to enable instance comparison. We call keys this predicates set similar to the notion of keys in relational databases. We explore and explain formally the different assumptions behind various key semantics.
technical-report-LIRMM.pdf (195.78 Ko) Télécharger le fichier
hal-00915798 , version 1 (09-12-2013)
  • HAL Id : hal-00915798 , version 1
  • PRODINRA : 314871
Michel Chein, Madalina Croitoru, Michel Leclère, Nathalie Pernelle, Fatiha Saïs, et al.. Defining Key Semantics for the Semantic Web : a Theoretical View. [Technical Report] LRI, Université Paris-Sud, CNRS, Universitée Paris-Saclay, France. 2013. ⟨hal-00915798⟩
267 Consultations
118 Téléchargements
