Enumeration of monadic second-order queries on trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Computational Logic Année : 2013
Wojciech Kazana
  • Fonction : Auteur
  • PersonId : 948901
Luc Segoufin
We consider the enumeration problem of monadic second-order (MSO) queries with first-order free variables over trees. Bagan showed ub 2006 that this problem is in CDlin. An enumeration problem belongs to CDlin if for an input structure of size n it can be solved by: * an O(n) precomputation phase building an index structure, * followed by a phase enumerating the answers with no repetition and a constant delay between two consecutive outputs. In this article we give a different proof of this result based on the deterministic factorization forest decomposition theorem of Colcombet.
enummso.pdf (188.79 Ko) Télécharger le fichier
hal-00916400 , version 1 (10-12-2013)
  • HAL Id : hal-00916400 , version 1
Wojciech Kazana, Luc Segoufin. Enumeration of monadic second-order queries on trees. ACM Transactions on Computational Logic, 2013, 14 (4). ⟨hal-00916400⟩
120 Consultations
199 Téléchargements
