Formal Proof in Coq and Derivation of a Program in C++ to Compute Convex Hulls - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article presents a generic method to build programs in computational geometry from their specifications. It focuses on a case study namely computing incrementally the convex hull of a set of points in the plane. Our program to compute convex hulls is specified and proved correct using the Coq proof assistant. A concrete implementation in Ocaml is then automatically extracted and an efficient C++ program is derived (by hand) from the specification.
CH-submitted2011.pdf (324.36 Ko) Télécharger le fichier
hal-00916880 , version 1 (10-12-2013)
Christophe Brun, Jean-François Dufourd, Nicolas Magaud. Formal Proof in Coq and Derivation of a Program in C++ to Compute Convex Hulls. Automated Deduction in Geometry (Post-proceedings), Sep 2012, Edinbourg, United Kingdom. pp.71-88, ⟨10.1007/978-3-642-40672-0_6⟩. ⟨hal-00916880⟩
Collections
CNRS
131 Consultations
774 Téléchargements
