Partitioning Methods On Dissimilarity Matrices Set - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We introduce partitioning clustering models and algorithms that are able to partitioning objects taking into account simultaneously their relational descriptions given by multiple dissimilarity matrices. The aim is to obtain a collaborative role of the different dissimilarity matrices in order to obtain a final consensus partition.
SFC-DIST-V1.pdf (96.44 Ko) Télécharger le fichier
hal-00916906 , version 1 (10-12-2013)
  • HAL Id : hal-00916906 , version 1
Francisco F. A.T. de Carvalho, Yves Lechevallier. Partitioning Methods On Dissimilarity Matrices Set. European Conference on Data Analysis, GfKl and SFC, Jul 2013, Luxembourg, Luxembourg. ⟨hal-00916906⟩
Collections
INRIA INRIA2
125 Consultations
46 Téléchargements
