A Symbolic Transformation Language and its Application to a Multiscale Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2014
The context of this work is the design of a software, called MEMSALab, dedicated to the automatic derivation of multiscale models of arrays of micro- and nanosystems. In this domain a model is a partial differential equation. Multiscale methods approximate it by another partial differential equation which can be numerically simulated in a reasonable time. The challenge consists in taking into account a wide range of geometries combining thin and periodic structures with the possibility of multiple nested scales. In this paper we present a transformation language that will make the development of MEMSALab more feasible. It is proposed as a Maple package for rule-based programming, rewriting strategies and their combination with standard Maple code. We illustrate the practical interest of this language by using it to encode two examples of multiscale derivations, namely the two-scale limit of the derivative operator and the two-scale model of the stationary heat equation.
0.pdf (315.57 Ko) Télécharger le fichier
hal-00917323 , version 1 (11-12-2013)
hal-00917323 , version 2 (12-12-2013)
Walid Belkhir, Alain Giorgetti, Michel Lenczner. A Symbolic Transformation Language and its Application to a Multiscale Method. Journal of Symbolic Computation, 2014, 65, pp.49 - 78. ⟨10.1016/j.jsc.2014.01.004⟩. ⟨hal-00917323v2⟩
254 Consultations
195 Téléchargements
