Ontology matching: state of the art and future challenges - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Knowledge and Data Engineering Année : 2013
Pavel Shvaiko
  • Fonction : Auteur
  • PersonId : 1323368
After years of research on ontology matching, it is reasonable to consider several questions: is the field of ontology matching still making progress? Is this progress significant enough to pursue some further research? If so, what are the particularly promising directions? To answer these questions, we review the state of the art of ontology matching and analyze the results of recent ontology matching evaluations. These results show a measurable improvement in the field, the speed of which is albeit slowing down. We conjecture that significant improvements can be obtained only by addressing important challenges for ontology matching. We present such challenges with insights on how to approach them, thereby aiming to direct research into the most promising tracks and to facilitate the progress of the field.
shvaiko2013a.pdf (313.99 Ko) Télécharger le fichier
hal-00917910 , version 1 (12-12-2013)
Pavel Shvaiko, Jérôme Euzenat. Ontology matching: state of the art and future challenges. IEEE Transactions on Knowledge and Data Engineering, 2013, 25 (1), pp.158-176. ⟨10.1109/TKDE.2011.253⟩. ⟨hal-00917910⟩
1126 Consultations
10471 Téléchargements
