An unfitted Nitsche method for incompressible fluid-structure interaction using overlapping meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2014
Erik Burman
  • Fonction : Auteur
  • PersonId : 940966
We consider the extension of the Nitsche method to the case of fluid-structure interaction problems on unfitted meshes. We give a stability analysis for the space semi-discretized problem and show how this estimate may be used to derive optimal error estimates for smooth solutions, irrespectively of the mesh/interface intersection. We also discuss different strategies for the time discretization, using either fully implicit or explicit coupling (loosely coupled) schemes. Some numerical examples illustrate the theoretical discussion.
RR-8424.pdf (951.96 Ko) Télécharger le fichier
hal-00918272 , version 1 (13-12-2013)
hal-00918272 , version 2 (20-12-2013)
hal-00918272 , version 3 (28-04-2014)
Erik Burman, Miguel Angel Fernández. An unfitted Nitsche method for incompressible fluid-structure interaction using overlapping meshes. Computer Methods in Applied Mechanics and Engineering, 2014, 279, pp.497-514. ⟨10.1016/j.cma.2014.07.007⟩. ⟨hal-00918272v3⟩
455 Consultations
515 Téléchargements
