The molecular signal for the adaptation to cold temperature during early life on Earth - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Biology Letters Année : 2013
Several lines of evidence such as the basal location of thermophilic lineages in large-scale phylogenetic trees and the ancestral sequence reconstruction of single enzymes or large protein concatenations support the conclusion that the ancestors of the bacterial and archaeal domains were thermophilic organisms which were adapted to hot environments during the early stages of the Earth. A parsimonious reasoning would therefore suggest that the last universal common ancestor (LUCA) was also thermophilic. Various authors have used branch-wise non-homogeneous evolutionary models that better capture the variation of molecular compositions among lineages to accurately reconstruct the ancestral G + C contents of ribosomal RNAs and the ancestral amino acid composition of highly conserved proteins. They confirmed the thermophilic nature of the ancestors of Bacteria and Archaea but concluded that LUCA, their last common ancestor, was a mesophilic organism having a moderate optimal growth temperature. In this letter, we investigate the unknown nature of the phylogenetic signal that informs ancestral sequence reconstruction to support this non-parsimonious scenario. We find that rate variation across sites of molecular sequences provides information at different time scales by recording the oldest adaptation to temperature in slow-evolving regions and subsequent adaptations in fast-evolving ones.
manuscriptSignalTemperature_newSub_version10.pdf (81.53 Ko) Télécharger le fichier
hal-00918283 , version 1 (17-12-2013)
Mathieu Groussin, Bastien Boussau, Sandrine Charles, Samuel Blanquart, Manolo Gouy. The molecular signal for the adaptation to cold temperature during early life on Earth. Biology Letters, 2013, 9 (5), pp.20130608. ⟨10.1098/rsbl.2013.0608⟩. ⟨hal-00918283⟩
204 Consultations
175 Téléchargements
