Results of the Ontology Alignment Evaluation Initiative 2013 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Heiko Paulheim
Ondrej Zamazal
Ontology matching consists of finding correspondences between semantically related entities of two ontologies. OAEI campaigns aim at comparing ontology matching systems on precisely defined test cases. These test cases can use ontologies of different nature (from simple thesauri to expressive OWL ontologies) and use different modalities, e.g., blind evaluation, open evaluation and consensus. OAEI 2013 offered 6 tracks with 8 test cases followed by 23 participants. Since 2010, the campaign has been using a new evaluation modality which provides more automation to the evaluation. This paper is an overall presentation of the OAEI 2013 campaign.
Autre [cs.OH]
oaei13_paper0.pdf (342.93 Ko) Télécharger le fichier
hal-00918494 , version 1 (13-12-2013)
  • HAL Id : hal-00918494 , version 1
Bernardo Cuenca Grau, Zlatan Dragisic, Kai Eckert, Jérôme Euzenat, Alfio Ferrara, et al.. Results of the Ontology Alignment Evaluation Initiative 2013. OM: Ontology Matching, Oct 2013, Sydney, Australia. pp.61-100. ⟨hal-00918494⟩
1613 Consultations
1110 Téléchargements
