Flauncher and DVMS -- Deploying and Scheduling Thousands of Virtual Machines on Hundreds of Nodes Distributed Geographically - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Although live migration of virtual machines has been an active area of research over the past decade, it has been mainly evaluated by means of simulations and small scale deployments. Proving the relevance of live migration at larger scales is a technical challenge that requires to be able to deploy and schedule virtual machines. In the last year, we succeeded to tackle such a challenge by conducting experiments with Flauncher and DVMS, two frameworks that can respectively deploy and schedule thousands of virtual machines over hundreds of nodes distributed geographically across the Grid'5000 testbed.
main.pdf (226.47 Ko) Télécharger le fichier
hal-00920094 , version 1 (17-12-2013)
  • HAL Id : hal-00920094 , version 1
Daniel Balouek, Adrien Lebre, Flavien Quesnel. Flauncher and DVMS -- Deploying and Scheduling Thousands of Virtual Machines on Hundreds of Nodes Distributed Geographically. IEEE International Scalable Computing Challenge (SCALE 2013), held in conjunction with CCGrid'2013, May 2013, Delft, Netherlands. ⟨hal-00920094⟩
421 Consultations
208 Téléchargements
