Automatic Decidability for Theories with Counting Operators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The notion of schematic paramodulation has been introduced to reason on properties of (standard) paramodulation. We present a schematic paramodulation calculus modulo a fragment of arithmetics, namely the theory of Integer Offsets. This new schematic calculus is used to prove the decidability of the satisfiability problem for some theories equipped with counting operators. We illustrate our theoretical contribution on theories representing extensions of classical data structures, e.g., lists and records.
TushkanovaRGK-ADDCT13.pdf (108.98 Ko) Télécharger le fichier
hal-00920496 , version 1 (18-12-2013)
  • HAL Id : hal-00920496 , version 1
Elena Tushkanova, Christophe Ringeissen, Alain Giorgetti, Olga Kouchnarenko. Automatic Decidability for Theories with Counting Operators. Automated Deduction: Decidability, Complexity, Tractability (workshop ADDCT), Jun 2013, Lake Placid, United States. ⟨hal-00920496⟩
164 Consultations
70 Téléchargements
