Game-theoretically Optimal Reconciliation of Contemporaneous Hierarchical Time Series Forecasts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
In hierarchical time series (HTS) forecasting, the hierarchical relation be- tween multiple time series is exploited to make better forecasts. This hierarchical relation implies one or more aggregate consistency constraints that the series are known to satisfy. Many existing approaches, like for example bottom-up or top- down forecasting, therefore attempt to achieve this goal in a way that guarantees that the forecasts will also be aggregate consistent. We propose to split the problem of HTS into two independent steps: first one comes up with the best possible fore- casts for the time series without worrying about aggregate consistency; and then a reconciliation procedure is used to make the forecasts aggregate consistent. We introduce a Game-Theoretically OPtimal (GTOP) reconciliation method, which is guaranteed to only improve any given set of forecasts. This opens up new possibil- ities for constructing the forecasts. For example, it is not necessary to assume that bottom-level forecasts are unbiased, and aggregate forecasts may be constructed by regressing both on bottom-level forecasts and on other covariates that may only be available at the aggregate level. We illustrate the benefits of our approach both on simulated data and on real electricity consumption data.
gtop.pdf (144.83 Ko) Télécharger le fichier
hal-00920559 , version 1 (18-12-2013)
  • HAL Id : hal-00920559 , version 1
Tim van Erven, Jairo Cugliari. Game-theoretically Optimal Reconciliation of Contemporaneous Hierarchical Time Series Forecasts. 2013. ⟨hal-00920559⟩
423 Consultations
1106 Téléchargements
