Projecting points onto planar parametric curves by local biarc approximation
This paper proposes a geometric iteration algorithm for computing point projection and inversion on planar parametriccurves based on local biarc approximation. The iteration begins with initial estimation of the projection of theprescribed test point. For each iteration, we construct a biarc that locally approximates a segment on the originalcurve starting from the current projective point. Then we compute the projective point for the next iteration, as well asthe parameter corresponding to it, by projecting the test point onto this biarc. The iterative process terminates whenthe projective point satisfies the required precision. Examples demonstrate that our algorithm converges faster and isless dependent on the choice of the initial value compared to the traditional geometric iteration algorithms based onsingle-point approximation.
